panelis » Tehniski jautājumi
Forums » Tehniski jautājumi » panelis
panelis ( 3536 )
blumpis
7 ziņas
man tads jautajums varbut kads zina atbildi. paneli mirgo lampinas tur kur pecka regulejas u.c. Mirgo kadas 20min pec tam nodziest. Dzirdeju ka jauzpilda kondicionieris, uzpildiju tapat mirgo. :roll: :roll: :roll:
GRAND VOYAGER 2.5TD
Raitisr
43 ziņas
Ja mirgo lampinjas tas nozime ka ir testmode un kautkas nav kartība
No test modes var iziet paturot aizmugurejo loga tirishanas pogu
Te bus infa
CALIBRATION/COOLDOWN LED DISPLAY CODES
See table for definition of flashing LEDs. If no problems are found, the control functions normally.
LEDS PASS/FAIL CORRECTIVE ACTION
NO LEDS FLASHING-NORMAL OPERATION PASSED CALIBRATION, DIAGNOSTICS AND COOLDOWN NONE
REAR WIPER AND INTERMITTENT LEDS FLASH SIMULTANEOUSLY FAILED CALIBRATION DIAGNOSTICS RUN CALIBRATION TEST
A/C AND RECIRC LEDS FLASH SIMULTANEOUSLY FAILED COOLDOWN RUN COOLDOWN TEST
REAR WIPER AND INTERMITTENT LEDS ARE FLASHING SIMULTANEOUSLY A/C AND RECIRC LEDS ARE FLASHING SIMULTANEOUSLY FAILED CALIBRATION, DIAGNOSTICS AND FAILED COOLDOWN TEST RUN CALIBRATION TEST
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
Set Blower motor ON HIGH
Set Mode position to Panel
Open all A/C outlets
Set Temperature to Cold (Both slide pots if equipped)
Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LEDs light)
RESULTS:
All LEDs will turn on for 5 Seconds
Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.
Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
After all tests have passed, Calibration Diagnostics and Cooldown can be run separately.
COOLDOWN TEST ENTRY
TO INITIATE TESTS:
Depress WASH and A/C simultaneously for 5 Seconds
NOTE: Prior to start of test, If the evaporator is already cold, the system will fail test. To correct, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test.
Chrysler Voyager 3.3 LE 1996 Benzins+Gaze
