Mirgo diodītes, pie kondicioniera slēdža » Tehniski jautājumi
Forums » Tehniski jautājumi » Mirgo diodītes, pie kondicioniera slēdža
Mirgo diodītes, pie kondicioniera slēdža ( 3838 )
Oxygen68
8 ziņas
Var būt kāds ir saskāries - periodiski mirgo diodīter uz kondiķa ieslēgšanas paneļa, kā to varētu novērst.
dodge 3,3 98.g.
Locis
556 ziņas
Kkur forumā bija par to rakstīts!
Vajag testu uztaisīt tam panelim (bija speciāla pogu kombinācija) un tad viss atkal nostājas savās vietās - nemirgo :wink:
Savam auto arī esmu taisījis, tik neatceros vairs... :?
Atradu kaut ko:
http://autorepair.about.com/library/a/1i/bl667i.htm
Calibration/Diagnostics Test Entry
TO INITIATE TESTS:
* Set Blower motor ON HIGH
* Set Mode position to Panel
* Open all A/C outlets
* Set Temperature to Cold (Both slide pots if equipped)
* Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LEDs light)
RESULTS:
* All LEDs will turn on for 5 Seconds
* Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cool-down test is running if A/C and RECIRC are alternately flashing.
* Acceptable result is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
* After all tests have passed, Calibration Diagnostics and Cool-down can be run separately.
Pamēgini!! :wink: Man izdevās tā novākt to mirgošanu!!
bija Dodge Caravan 3,0l;98.
Locis
556 ziņas
Un te vēl par to pašu :wink:
:arrow: http://www.dodgetalk.com/forums/archive/index.php/t-194461.html
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
RESULTS:
* Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.
* Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
* After all tests have passed, Calibration Diagnostics and Cooldown can be run separately.
COOLDOWN TEST ENTRY
TO INITIATE TESTS:
* Depress WASH and A/C simultaneously for 5 Seconds
NOTE: Prior to start of test, If the evaporator is already cold, the system will fail test. To correct, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test.
RESULTS:
* Cooldown Test is running when A/C and RECIRC. are alternately flashing. If A/C and RECIRC. are flashing simultaneously, Cooldown has failed.
CALIBRATION DIAGNOSTICS AND COOLDOWN ABORT
Test can be aborted by doing one of the following:
* Depressing Rear Window Defogger, RECIRC and Rear Wiper buttons.
* Cycling Ignition OFF and then ON.
* Control will automatically abort after 15 minutes from the time Calibration Diagnostics and Cooldown was entered.
The HVAC control module will return to normal operation or may indicate unsuccessful Calibration Diagnostics or Cooldown test by LEDs flashing simultaneously.
EEPROM DATA
Calibration Diagnostics, Cooldown Status and evaporator temperature Fin Sensor values are stored in an EEPROM memory internal to the control. The microcomputer within the HVAC control module uses this information:
* To determine if Cooldown needs to run
* For proper position of the Heater-A/C unit assembly doors
pete geppert
02-19-2008, 06:14 PM
Thanks!!!!!!
I did what you said and it is working with no more flashing lights.
rita0306
37 ziņas
jā...ja es saprastu kaut ko.....
pingvīns
39 ziņas
rita0306: "jā...ja es saprastu kaut ko....."
http://www.voyagerclub.lv/forums/tehniski-jautajumi/show/36103?start=8
voyager 3,3 98g.b/g ; grand voyager 2006 g. 3,3 b/g
