Dzesēšanas šķ. » Tehniski jautājumi
Forums » Tehniski jautājumi » Dzesēšanas šķ.
Dzesēšanas šķ. ( 3504 )
madyl
55 ziņas
Sveiki. Atvainojos par stulbo jautajumu, bet vai kāds nevar ieteikt, kāds būtu jālej dzesēšanas škidums(firma, nosaukums kāsa utt). Agrāk tiku iebaidīts, par to ka Amerikas autiņiem galvenais nedrīkst jaukt tos !!
madyl
55 ziņas
Sorry! :roll: Par 2001 T&C 3,8
No 2001g. Voyageriem servisa rokasgrāmatā rakstīts:
"The use of aluminum cylinder blocks, cylinder heads, and water pumps requires special corrosion protection. Mopar Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769), or the equivalent
ethylene glycol base coolant with hybrid organic corrosion inhibitors (called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant
offers the best engine cooling without corrosion when mixed with 50% Ethylene Glycol and 50% distilled water to obtain a freeze point of -37°C (-35°F). If it
loses color or becomes contaminated, drain, flush, and replace with fresh properly mixed coolant solution. The green coolant MUST NOT BE MIXED with
the orange or magenta coolants. When replacing coolant the complete system flush must be performed before using the replacement coolant.
CAUTION: MoparT Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Doing so
will reduce the corrosion protection and may result in premature water pump seal failure. If non-HOAT coolant is introduced into the cooling system in an
emergency, it should be replaced with the specified coolant as soon as possible."
Pirms pāris gadiem Mopar 5 Year/100,000 Mile Formula 5l koncentrāts maksāja Ls17 (TC Motorā).
Tagad jau var dabūt atbilstošus no citiem ražotājiem, piemēram
http://www.tehniskaisveikals.lv/lv/kata ... rated--5l/
Normunds
94 ziņas
Vēl ir šāda Texaco dzesēšanas šķidrums.
http://vamotors.lv/saits/lat/products.php
