Augšējā datu paneļa programmēšna » Tehniski jautājumi
Forums » Tehniski jautājumi » Augšējā datu paneļa programmēšna
Augšējā datu paneļa programmēšna ( 4428 )
:arrow: www.homelink.com - informācijai
[quote]1. Press and hold the two outer HomeLink buttons, and
release only when the indicator light begins to flash (after
20 seconds). Do not hold the buttons for longer than 30
seconds and do not repeat step one to program a second
and/or third hand-held transmitter to the remaining two
HomeLink buttons.
2. Position the end of your hand-held transmitter 1-3
inches (3-8 cm) away from the HomeLink buttons while
keeping the indicator light in view.
3. Simultaneously press and hold both the HomeLink
button that you want to train and the hand-held transmitter
buttons. Do not release the buttons until step 4
has been completed.
NOTE: Some gate operators and garage door openers
may require you to replace this Programming Step 3 with
procedures noted in the Gate Operator/Canadian Programming
section.
4. The HomeLink indicator light will flash slowly and
then rapidly after HomeLink successfully receives the
frequency signal from the hand-held transmitter. Release
both buttons after the indicator light changes from the
slow to the rapid flash.
5. Press and hold the just trained HomeLink button and
observe the indicator light. If the indicator light stays on
constantly, programming is complete and your device
should activate when the HomeLink button is pressed
and released.
NOTE: To program the remaining two HomeLink buttons,
begin with Programming step two. Do not repeat
step one.
If the indicator light blinks rapidly for two seconds and
then turns to a constant light continue with (Programming(
steps 6-8 to complete the programming of a rolling
code equipped device (most commonly a garage door
opener).
6. At the garage door opener receiver (motor-head unit)
in the garage, locate the learn or smart button. This
can usually be found where the hanging antenna wire is
attached to the motor-head unit.
7. Firmly press and release the learn or smart button.
(The name and color of the button may vary by manufacturer.)
NOTE: There are 30 seconds in which to initiate step
eight.
8. Return to the vehicle and firmly press, hold for two
seconds and release the programmed HomeLink button.
Repeat the (press/hold/release( sequence a second time and, depending on the brand of the garage door opener
(or other rolling code equipped device), repeat this
sequence a third time to complete the programming.
HomeLink should now activate your rolling code
equipped device.
step one. For questions or comments, please contact
HomeLink at www.homelink.com or 1-800-355-3515."
[quote]Erasing HomeLink Buttons
To erase programming from the three buttons (individual
buttons cannot be erased but can be 9reprogrammed9 -
note below), follow the step noted:
² Press and hold the two outer HomeLink buttons until
the indicator light begins to flash-after 20 seconds.
Release both buttons. Do not hold for longer that 30
seconds. HomeLink is now in the train (or learning)
mode and can be programmed at any time beginning
with Programming - step 2."
šitais viss no Chrysler Town and Country 2004 user manual..
